Hydraulic fluid foaming
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
Turned tractor off after mowing and pulled dipstick right away and noticed the hydraulic fluid was foaming. It dissipated in 10 seconds. Is this normal to have this happen? Bx2380.
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
105
217
wisconsin
are you using the correct fluid and not some special secret recipe
9,143
Yes, quite normal.
By the time the fluid gets to the suction the bubbles have dispersed.
9,143
Out of curiosity what causes this to occur?
Just normal operation of a gear pump, gears in the transmission and the way fluid is moved it entrains air into it.
This is why the suction is on the bottom and why there is so much fluid in the system.
spanky2380
bx2380
Aug 29, 2023
21
11
michiagn
Thank you for the explnation. I'm trying to better understand hydrolics and there is a lot to learn.
