Hydraulic FIlter
anglerhideaway
L275
May 26, 2015
Goldendale
For the life of me, my brother Darrell and my other brother Darrell, we cannot locate where the hydraulic fluid filter is on our 1982 L245 Kubota tractor (4 wheel drive). It does have the loader option on it and we can trace the hoses on the loader to the main valve area...we have that many brains between us. But our 'original' service chart shows a picture that we cannot locate. Can some one help us and post a VERY clear picture with an arrow that says "Hey idiot...its right here!?"
Thanks so much- Younger Darrell
2,150
I have a L185 and the L245 has the same type of filter in the transmission case. Look where the hydraulic pump is on the rear side of the engine. Follow the pipes from that back to where it attaches to the transmission. Then on the opposite side of the tractor in the same location you should see a small cover bolted to the side of the transmission with a dome shape.
On the L185 it is on the left (sitting in the seat) side at the back of the foot board. I assume it is similar on the L245.
Unbolt that cover and there will be a o-ring for sealing that to the transmission. There will be a spring installed to hold the filter in. Sticking out of the transmission should be a small protrusion that you pull out (the end of the filter screen). You may need to grab it with needle nose pliers.
The filter is a tube of fine mesh that can be washed if it is still intact.
I would suggest that you get a new filter, o-ring and replace those if you have the time to wait on the parts. I would be afraid the o-ring would fail if not new.
For future reference - go to Kubota.com, parts, illustrated parts list and agree to their legal terms. Search for L245 then select you more exact model (l245DT) and you will get the parts list for your tractor in sections. You can also search by part name by selecting some obscure term like "book search" and using the pull down selections on that screen.
Oh and say hello to your brother Darrell and your other brother Derryl
8,830
EDIT: Got it wrong the first time! :eek:
Sorry Russell, that would be the L245 your thinking of.
The L275 has a spin on filter on top of the hydraulic pump. :D
P/N H3840-37710
Also sending you a link for a WSM for download!
2,150
NIW, I don't know what model he has now!!!
Text in post says L245 but profile note says L275???
Anyway I guess he has the answer to either model now. Thanks for pointing out that he probably has the L275!
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
Russell's description is correct for my L245DT. Tubular screen that comes in from the left hand side at the bottom of the case. I got a replacement from the dealer because mine was in pretty crappy shape, it was only about $15.
8,830
Russell you are exactly right!!! :eek:
I too gave the same answer as you the first time before my edit, so yes I'm confused too! :confused:
Ok same as Russell in first post for the L245!!!
Oh I'm soooo confused!!!!!:confused::confused::confused: :eek::eek::eek::eek:
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
Lovells, Mi
Nothing quite as confusing as dealing with Darrell, Darrell, and Darrell.:rolleyes::rolleyes::rolleyes:
