Hydraulic cylinder replacement
Csqualls
3130D HST
Oct 24, 2019
Rockwall Texas usa
I took my lift cylinder on my LA 513 loader to the dealer to be repacked and they said it was bent and pitted, could not be fixed. They said replacement was 795.
BigG
Sep 14, 2018
1,951
770
West Central,FL
Take it to a shop and see what they say.
BigG
Sep 14, 2018
1,951
770
West Central,FL
Where can I find the bore, and stroke , so I can check after market, the tractor is 50 miles away
Take the cylinder to a hydraulic shop that is not a tractor dealer. The down and dirty is the dealer is out to make money so selling a new cylinder is probably more money then rebuilding one. So take it to a shop which makes its living rebuilding cylinders and see what they say. Then if they say replace it ask them to measure it for you. You will need the diameter of the holes for the pins, bore stroke and inlet locations.
Csqualls
3130D HST
Oct 24, 2019
Rockwall Texas usa
thanks , will do !
whitetiger
Nov 20, 2011
2,921
1,383
Kansas City, KS
How many businesses do you know of that are not open to making a profit???????????
Few dealers are equipped to manufacture a replacement cylinder shaft like a hydraulic repair facility, and they sure would not build it nonprofit.
BigG
Sep 14, 2018
1,951
770
West Central,FL
You missed my point. I want people to make money. That is how the world should work. I was trying to say to check with a repair shop before buying a new cylinder. The dealer is more than likely going to send a cylinder out to have it repaired then add a fee for his profit. This is all fine and good. I was saying to skip the dealer and go directly to the repair shop and save some money if it is repairable. If it is non-repairable then you go to the next step of buying a replacement at an outside supplier or at the dealer.
There was no intent to imply the dealer was doing anything wrong. There are different paths to get to the same destination.
When I have to have any type of work done I tell people I expect you to make a profit on my job I just do not want it to be a whole year's profit.
I called a general repair shop to have a new radiator put in one of my trucks. He wanted more then $400 to do the job. I called a radiator repair shop and had it replaced for less then $200. Both places would have made money but one was making a lot more money then the other.
