Hyd problem
GAZKT
Kubota l4610/852 loader
Mar 21, 2016
Hamilton Montana
Have l4610 with 852 loader added quick disconnects off loader valve to rear auxiliary ports.i cannot use the tilt cylinder ports only lift ports does any one have and answer the log splitter is a 2 way cylinder?
6,609
Little confused as to what you have done? :confused:
Have you tee-ed the connections off of the valve or have you made a loop, or just have 2 lines that dead end at the rear without a valve inline?
rbargeron
Jul 6, 2015
1,171
238
western ma
It's tricky using the FEL valve to operate other things. The curl's dump circuit isn't "normal". It powers both cylinder hoses, giving better control of dump motion. I use the FEL valve for my front snowblower. The curl circuit turns the chute. It only works plumbed one way, and then only because the load is small. The difference in cylinder areas above and below the piston is enough so it moves. But it wouldn't work well for a splitter - there's not enough area difference to produce useful splitting force. Hope this helps. Dick B.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
May want to look at doing what I did on my L3000. I used the feed line for the loader to go to another valve and then back to the loader. The new valve controls the rear remotes I added. Very simple and works perfect.
