Less than a cup plus what is in the filter. The oil does not continue to drain when the filter is off on the BX series.How much hyd oil will I lose changing the filter on a bx2380?
I always just used the oil the filter will be filtering for gasket lubrication when changing oil filters.Don’t be in too-much of a hurry. Take the time to inspect and clean off the mounting base and to assure that ALL of the old filters’ gasket was removed. (and do not lubricate the new gasket with oil or grease as is often suggested because it will “coke” and GLUE the new gasket to the mounting base. Instead, smear a bit of silicone grease on the new gasket to accomplish what is actually intended…. lubricating the new gasket so it does not deform or slip or tear during installation…. while insuring that when you next remove the filter the gasket will not stick to the mounting base.)
I get the importance of upmost reliability with aircraft.The intent of lubing the gasket is to prevent distortion during installation…not to seal the gasket. Silicone grease is specified for the spin on aircraft filters…so that’s what I started using about 30 years ago on all spin on filters and discovered that they all remove so much easier later-on while still accomplishing the original intent. Using oil or grease “sticks” the gasket to the mounting base and makes it difficult to remove the filter as well as sometimes causing the old gasket to remain on the engine, etc….. and causing problems with the new filter if not caught.
I would never take a chance of transferring dirt from anything to a new filter. Just use a bit of the new oil since it is right there.I often take the old filter and rub its oily gasket against the new one.
Shadetrees have rebuilt engines for years on dirt. i wouldn't, but a tad of dirt isn't killing any machine.I would never take a chance of transferring dirt from anything to a new filter. Just use a bit of the new oil since it is right there.
Maybe not an old Johnny Popper, But these new tractors every tiny piece of dirt that can get into the system can do some serious damage.Shadetrees have rebuilt engines for years on dirt. i wouldn't, but a tad of dirt isn't killing any machine.
More forgiving than most think. Fuel? No.Maybe not an old Johnny Popper, But these new tractors every tiny piece of dirt that can get into the system can do some serious damage.
It only takes one speck of grit to stick the oil pressure bypass open, you can then spread butter and jam on that engine because now it's toast.More forgiving than most think. Fuel? No.
