HST problem
John6238
L45 loader backhoe
Jul 24, 2020
Kentucky
Hello, I have a 2012 l45 loader backhoe with around 700 hours on it. The problem I am having is after the tractor reaches normal operating temp I begin to have forward and reverse issues. The tractor will start jumping forward and often the reverse will completely stop working. I took it to a Kubota shop, after almost a month they had made no progress and racked up nearly 5 grand in shop hours. Any advice would be greatly appreciated.
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
213
45
Dickson, TN
Yep, you should be really sore in a certain body part area. It is at the wrong shop.
You said a Kubota shop; it this a Kubota dealer familiar with your model tractor? My local dealer is clueless about the M size tractors so I would never use them for major repairs. Like mine, yours may know the mowers and B series machines really well but not much else. Sure sounds that way.
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
358
89
Canton, MS
What the heck did the Kubota Dealership do to it that cost you $5000 and didnt fix the problem? I'd report them to anyone that would listen. BBB, Small claims court, Judge Judy.
John6238
L45 loader backhoe
Jul 24, 2020
Kentucky
They said they were, it was a dealer, and the bill was hours and they fixed a charging issue that I didn't know existed. Would really like to figure out the problem, it runs so we'll for about 30 mins.
Mark_BX25D
Bx25D
Jul 19, 2020
1,785
1,301
They racked up 50 or more hours and still don't have a clue? I'd be complaining to Kubota about that dealer.
How has the maintenance been on that transmission? Fluids and filters changed regularly?
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
956
1,269
Pittsburgh
While an issue with the charge pump fits your symptoms I wonder if $5000 would've been better spent on a new charge pump or complete Xmission replacement.
John6238
L45 loader backhoe
Jul 24, 2020
Kentucky
Charge pump, I'll check into that. Another thing I thought was strange, it sounds like the engine is under a load when you are lowering the loader bucket. I'm not super familiar with hydro systems but I wouldn't think it would require much force to lower it.
