HST pressure tester?
Peter.h
Kubota B26TL
Apr 14, 2025
Los Angeles, CA
Thanks for reviewing my video!
Yes, I feel the clutch is still good.
Correct, I put it in HIGH range with PTO engaged. Pretty much did a brake stand and no effect on the PTO. Rotated as normal.
I guess I'm onto HST pressures now.
Well, I still have travel, right? I can still limp the tractor around- both forward and reverse.
I think I'm going to take a chance on that amazon pressure testing kit I posted earlier with the 5 gauges and numerous fittings.
How did it go? My B26 is showing similar symptoms so I’m curious about your journey. Which adapters did you end up using for the HST test ports?
