HST pedal
meat12
'01 L4330
Feb 20, 2012
WI
I am looking at possibly buying a L4330 with HST. When I took it around the yard for a test driver I noticed that when you push forward on the pedal you will continue to go forward even when you remove your foot. Is that normal, or should it return to zero?
Justin
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
My HST on my BX24 sometimes does that as well. When it starts to act up I grease the peddle zert in the floorboard. Problem solved for awhile. I don't know if your model has the same zert available.
Hope that helps
TripleR
Sep 16, 2011
1,911
SE Missouri
It should return to center.
meat12
'01 L4330
Feb 20, 2012
WI
Ok thanks guys. I will look into the pedal grease zert when I go and look at it again on Friday. Could there be any other reason for this issue other than a sticky pivot point?
alex
MX5100
Feb 8, 2012
21
americus,ga
I have MX5100, when I remove my foot from the pedal it stops. There is a lever on my left that is like a cruise control lever. Don't know if you have that as well, but I would make sure that it is not engaged.
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
After reading the answers which are good, I will add my two cents. My will do this also. It is cold weather. You are in WI and I am in Vermont. Some of the answers are from the south part of the country.This will be slow to go back to center and the more grease in cold weather will be more slow to center. Try spraying some Marvel Mystery Oil or something like that. It will free right up.
David Pidgeon
lenglenga
United States
<a href="http://www.lvtaschenonline.com/louis-vuitton-klassik/neuheiten.html">Neuheiten</a>
<a href="http://www.lvtaschenonline.com/louis-vuitton-klassik/neuheiten/mono-city-bags-briefcases.html">Mono City Bags & Briefcases</a>
<a href="http://www.lvtaschenonline.com/louis-vuitton-klassik/neuheiten/leather-city-bags-briefcases.html">Leather City Bags & Briefcases</a>
tk1469
147
North Central Michigan
I live in Michigan and once it got cold I noticed that my HST pedal didn't always return to the true neutral position. But my Kubota mechanic told me to keep it lubricated with Chain Lube. I give it a quick spray every now and then and its been PERFECT even in subzero weather.
Good Luck.
