How to repair a cut in R4 Tire Tread ???
Arausio
L2501, LA525, BH77
Oct 20, 2021
WI
Hello all -
My R4 tire has a slice cut in the tread - the tire itself is fine. I tried to glue the tread flap using
Xtra-Seal Chemical Vulcanizing Cement (8 oz.)
but it did not hold - and yes the joint was thoroughly cleaned before the vulcanizing cement was applied. Any suggestions would be appreciated. Thanks much.
5,688
curious, dld the instructions...
appears to be a 'contact' type cement so it HAS to be DRY before parts are joined.
According to the sheet can take up to 5 minutes based on temperature and humdidity levels....
maybe try again
clean/buff,apply but use toothpicks to keeps parts from each other for at LEAST 5 minutes then remove toothpick, press together hard and hold.
OntheRidge
Nov 1, 2020
407
476
I think I'd just let it be, doesn't look too serious.
Reactions: 8 users
8,747
My suggestion, and the hard honest truth, just forget about it.
Your not going to fix it where it will actually hold!
You've now got a used tire.
5,688
Curious so please explain why ?
The screw only goes into the 'LUG' ,horizontally, has NOTHING to do with the air inside or structural integrity of the tire/rim. The extra weight 'might' affect performance ??
8,747
There are too many reasons to write them all up!
je1279
Dec 6, 2020
828
581
Upstate NY
I agree that the tread cut appears to be minor and not something that will ultimately compromise your tire. If it bothers you, clean out the sliced area and apply an adhesive you feel will do the job. In the event that it fails down the road, shrug it off and continue to tractor on.
4,855
Looks like normal wear & tear to me. Whether it eventually chunks out or stays like it is, it’s irrelevant to performance.
armylifer
Mar 26, 2013
2,145
916
Thurston County, WA
I would just cut that little piece off with a sharp knife so it would not continue to tear off more tread. Cutting it off would prevent the torn piece from continuing to tear off more rubber in an unpredictable manner.
Reactions: 7 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,565
2,024
Western MT
I agree with cut it off (it looks small), so you can control how the tear continues.
If you don't want to do that, clean it really well with isopropyl alcohol or sand/shave it slightly . Then, use the vulcanizing cement, but leave it under pressure for a day or so in a warm location.
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
310
301
NW WI
I would just trim it.
This stuff is interesting though
KKBL
L2501 HST QA 525 loader, 42" forks, brush hog, grader/box/back blades
Jan 5, 2022
125
137
Girard, PA
I would just trim off the flap to avoid additional tearing as others have suggested. Save the flap as a reminder that you have used your tractor for actual work.:)
airbiscuit
Mar 18, 2021
310
301
NW WI
Or this!
armylifer
Mar 26, 2013
2,145
916
Thurston County, WA
Here is what to do when the tear gets really bad.
Hugo Habicht
G1900
Jun 24, 2024
594
792
Ireland
My experience with chinese supplied superglue in combination with rubber is very good. If that still works after your rubber cement attempt I do not know.
