how to remove mm mower
vtmbz
b7100, b5100
Oct 27, 2012
49
lowell vt
Im ready to remove my mower to overhaul the front axle pivots. THis is on a b5100 with front pto. Can I back over the mower deck (I think its a b4450) or do I have to drag it out from the side?
78Vette
F2690
Mar 14, 2010
109
SW Ont. Canada
Instead of battling with the MMM, trying to get it out, i install the FEL first and lift the front end off the ground, which makes removing the MMM a snap.
I did drive overtop the mower when i used to have a B1700. But, be careful because you could tip over if the rear wheels are not level. Had a few hairy moments doing this every spring and fall.
