How much tractor to run offset rear blade?
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
202
271
Hardy, VA
So buried in another thread about ditching next to a driveway there was discussion of using an offset rear blade tilted like this pic that I took from that thread.
My question for those not in that thread with more experience is the following:
1. Is a Bseries tractor with 26hp enough to effectively run a blade in this configuration?
2. Is there damage potential to the 3pt linkages from the leverage of a big ole blade offset like this?
3. What else am I not thinking through?
I have a nice used offset blade for sale here locally and I am trying to determine if I should buy it.
trikepilot
Jul 18, 2020
202
271
Hardy, VA
Sorry...
The blade size that I would prefer is a 5ft, however, the one that is available is a 6ft (photos from CL listing below)
JasonW
831
565
Al
If it’s a good deal, go for it. It doesn’t look very heavy which is good on your case.
As far as damaging your tractor linkage with it, you will run out of traction before breaking anything. But there is always an exception to that.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
131
130
Lakes Region, NH
I think a lot depends on what type of ditching and soil conditions. Creating a ditch where one does not already exist with an offset blade can be a lot more difficult on the tractor and 3pt than cleaning out an existing ditch. Suddenly encountering large rocks could really stress the 3pt arms. Creating a ditch from scratch would best be done digging with the bucket. Obviously that would take a lot of time since it is being done one bucket width at a time, but the advantage is you are not placing the spoils on the driveway requiring cleanup later.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,172
1,161
E.
The dynamic/ shock load of that configuration could be huge. I would worry about breaking stuff. I wouldn't operate a b series tractor in that position in my area.
If I did i would make sure that the operator took a very high degree of care respecting the possible dangers of breakage. Very very low and slow.
For sure you could make it work but for sure high level of something bad happening if mistake or carelessness made.
Kinda like using the outside edge of your bucket to dig stumps or rocks.. Lots of people do it all the time. Lots of people also bend their loaders.
trikepilot
Jul 18, 2020
202
271
Hardy, VA
This will be for cleaning out and maintaining existing ditches along a gravel driveway.
MtnViewRanch
913
378
Lakeside Ca.
For your circumstances, RUN, don't walk and purchase that blade.
For others, as always, circumstances can dictate what you can and can't do.
As far as ditching, yes it can be done.
Pictures are of my 8' blade putting in a temporary water line.
SDT
Apr 15, 2018
3,684
1,408
You might be able to do light maintenance of existing ditches with such a blade and your 2620 but you will not be able to excavate new ditches with either tractor or blade.
trikepilot
Jul 18, 2020
202
271
Hardy, VA
I have a backhoe with ripper for making any new ditches. I just need a better way to get the existing ditches cleaned out a few times a year
