How much are these worth?
Benhameen
Jan 27, 2013
713
135
Southern IL.
I have had these sitting around for a long time. I don't have a need for them and was thinking about putting them on craigslist. Anybody have an idea the value?
They're 35' long, I'd have to check the diameter. They came out of the Ohio river years ago.
Thanks !
4,186
Barge bridle chains,, and just how did you manage to get then out of the river in the first place hummmm
Benhameen
Jan 27, 2013
713
135
Southern IL.
A friend was working as an operator,I don't recall why or where on the river he was working but he dug them out of the mud. He showed up one day and asked if I wanted a couple of them, I said sure why not.
I was thinking about scrapping them but thought someone could use them.
live_roll
M108 / BX 25 / RTV 900 / ZD331 / M7060 / B1200 Mx5100 Ford 1500
Dec 16, 2009
53
Irricana Alberta
Well, there may just be the time you get one of those tractors REALLY stuck, and then there is no price you can put on those........... I'm not a hoarder, but nice to have something like that for backup...part of the "boy scout" kit....LOL I'd spray them down with a some old oil to keep them from deteriorating, and roll them up someplace dry, although that may just be a job in itself. But I'm sure some large acreage farmer with BIG equipment may be interested, as most lifting towing craning companies have to have certification on their slings and lifting devices.
Cheers and have a groovy day!!
Roger
Burt
L3700SU, box blade, 6 foot rhino blade, 1 bottom plow, 3 point receiver hitch.
Mar 24, 2012
337
Goldendale, WA USA
Roger is right. You never know if you need something like that.
In the logging community, stuff like that is used to drag logs out of tough spots. Sometimes, anything used for that purpose is called "green chain."
I'd hang on to them for any future use.
Burt
Benhameen
Jan 27, 2013
713
135
Southern IL.
Thanks for the replys, I've had them rolled up hanging for awhile.
I also have numerous other tow trap's and chains. I use those all the time but I yet to use these. They a pretty heavy compared to the others I have.
I will put some old oil on them, thats a good idea whether I get rid of them or not.
I was the thinking that a farmer or an heavy equipment outfit might get some use out of them.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
I would not soak then with old oil, to messy to pick up and tote around and get all over you. I'd spray it with some chain and cable lube or a coat of WD-40
