How many hours on your tractor.
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
1978 B7100---1800 ish
2002 B7500--- 540
2002 B2410 ---1470
troverman
Kubota M4D-071 and Kubota ZD-1211-72
Jun 9, 2015
1,189
268
NH
2002 L4310 - sold - 620 hours
2013 B2920 - 530 hours
2018 MX4800 - 20 hours so far
No problems with any of them, ever.
NoJacketRequired
May 25, 2016
444
Ottawa, Ontario
#1 B7510 has about 670 hours - no major issues
#2 B7510 has about 370 hours - no major issues
B2410 just purchased has about 2560 hours - had major repairs done to mid PTO driveline for its associated front-mount snowblower last year, likely about the 2500 hour mark.
While I'm not worried about reliability, I do like to know at what point things are likely to go wrong with these machines. Some designs have inherent weaknesses that manifest as failures within a certain number of operating hours. I come from the aerospace world where we regularly replace components based on operating hours, since those operating hours represent a certain safe proportion of their fatigue or other service-limiting design factor. As a result of my background, knowing what components have failed for other operators within a common operating hour range is very good data to have. I appreciate everybody sharing their results here.
Emark SK
BX1500D, RCK48-15BX, 6' blade, HD dumpcart,
Oct 1, 2018
Eston, Saskatchewan
I just bought my first tractor; BX1500D.
At the time of purchase it had 219 hours!
I've since added 5 hours to it before washing, waxing, and taking photos.
The previous owner used it to cut the grass around his aviation hanger and tow his planes in and out. It's been "hangered" it's entire life. lol.
Cglaza
L2500DT, BX2380, G6200H
Aug 30, 2015
176
Freeland, mi
1992 G6200H with 1380hrs
1999 L2500 with 564hrs
2018 BX2380 with 14hrs
Sent from my XT1710-02 using Tapatalk
Wildfire
Bought the BX25 new 16 months ago - now have 165 hrs mainly building a well road and other road maintenance. Only issue was a loose bolt on the HST linkage (thank you Wildfire for that solution).
Only regret is I should have bought it 10 years ago when I first thought about getting one. (What would I do with it? was the question then).
Your kindly welcome Andy. :D
twomany
B7200
Jul 10, 2017
793
139
Vermont
Just did an oil and filter change on the Bolens HT-23
200 hours on the Hobbs...
OH! I just put that hour meter on the year before last. ;-)
The B7200 Kubota has an hour meter, but it never changes no mater how much I use it.
That is after a new tack drive and cable. What gives? ;-)
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
322
147
Jefferson, Ohio
I have a 2008 L3540 with 1,600 hours on it. I run it pretty hard.
I was hauling heavy clay and broke a wheel bearing. It was a pretty easy fix.
The front steering seals started leaking at about 1,300 hours. It was also an easy fix.
I had a fuel fitting fall out of the filter housing. That was the only time it let me down.
Ryansweatt2004
2017 kubota L3901HST
Jul 2, 2015
205
West gardiner maine, USA
Bought my 2017 L3901HST brand new with .6 hours on it in August of last year and just did the 400 hour service after just over a year of owning it. I’ve done a ton of groundwork at my property which is where most of the hours have gone.
5,691
When I am on the tractor time has no meaning,,, unless its time to eat :D
Tchess450
BX23S with 60inch deck. implements, blade, forks, spreader, and more.
Jun 18, 2018
45
Pa
2017 BX23S 110 hours, about 18 months old. If it would stop raining maybe I could add a few hours.
johnjk
Apr 13, 2017
1,821
2,241
West Mansfield, OH
Bought mine used in March of 2017 with 94hrs on it and now have 146. Will be doing an engine oil/fuel filter change this weekend on it.
L35
Jun 13, 2010
717
831
CT
1998 just broke 1100hrs yesterday
