How many hours on your tractor.
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
104
24
Nampa, Idaho
My B3000HSDC has 270 hours and just normal maintenance.
My Allis Chalmers 5020 has almost 1100 hours and still is running the original tires .
KeithG
2000 Kubota B2710, Woods BH75 backhoe, LandPride York Rake, B2783 Snow Blower
Jan 1, 2016
129
Rindge, NH
Didn't we have some space mission some time back that had an improper O-ring or two that had a failure?
I believe that was the Challenger Space Shuttle disaster. The O-Ring on the solid rocket fuel failed which resulted in hot gases acting like a blow torch on that very large fuel tank... Boooom!
Sometimes the smallest inconceivable part problem can cause the most pain.
KeithG
Jan 1, 2016
129
Rindge, NH
B2710 bought new in 2000, 863 hours on it. Other than my son breaking a
headlight, a neighbor dropping a log on the hood I have had no issues caused
by bad parts or failure of parts.
Now if we want to talk critter issues then I will tell you I want to eradicate all
the mice on my property! Dang things caused wiring issues which luckily were
resolved when I upgraded the dynamo to an alternator.
KeithG
Jan 1, 2016
129
Rindge, NH
Yeah, it was either the wrong one, or it was damaged on installation.
It was actually due to the cold temperatures at the time of the launch. The
powers at NASA decided they could not wait any longer and went ahead
with the launch even though the outside temp was outside the specs
defined for the O-rings (i.e. it was too cold they should have waited to
launch).
Jpatrick
BX1850, L210, Various 3 point implements
Apr 4, 2017
100
Buckingham, Pa
Got a BX 1850 last October with 289 hrs on it. Its presently at 379 and on. I'm planning on new trans fluid at 500.
Also got an L210 showing 270 hrs. Blew the engine on that one, and I'm replacing it with a used engine. Rest of the tractor is consistent with low hrs. No play in wheels, and drag links almost like new.
conropl
L3560 HSDC
Oct 17, 2016
233
West Michigan
Bought a B2320HSD in 2014 and sold in for a good price this spring with 200 hours. Used year round keeping the drive up, mowing, loader work, lifting, and snowblowing. Not a single issue with it. Only thing I had to keep on hand were shear bolts for the blower.
Now have an L3560HSTC I got this spring, and have 45 hours on it. Threw a P2414 code, and dealer called Kubota rep who said it is an EGR failure. Said if it is not full of soot, it is likely going to need replacing (he told them to have one on hand when they check it out because usually they are defective when that code shows up). I can keep running until I take it in, but it will be covered under warranty. They will take care of it in September when I bring it in to have a front snow blower set up on it (last month they had a nice - low hour blower at a price I could not refuse). Other than that issue - which they are taking care of- it has been a great tractor.
Sent from my SM-T810 using Tapatalk
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
I bought my new B2650 in May of 2015. I now have 610 trouble free hrs on it. Has been an awesome machine doing all kinds of tasks.
Newlyme
M4900 w/loader, finish mower, tiller, auger, rake. BX24 w/loader, backhoe
May 27, 2015
628
74
Nelson Ohio USA
Well so far Bulldog is the winner. Having had a B7100 with 6000+ hours on it.
North Idaho Wolfman second and third L3450 4600 hours and B7100 3800 hours.
Let's see who else has some big numbers.
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Took delivery of my BX23S on March 23 of this year. It now has 117 hrs on it.
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I've only had my kubota a couple years, so only 600hrs. Now some of the other tractors I drive have 4000,7000,9000+
Sent from my LGMS330 using Tapatalk
Newlyme
May 27, 2015
628
74
Nelson Ohio USA
Lets see if we can find some more high hour tractors. So far we have 6000+, 4600, & 3800.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
My neighbor has a 4440 JD with about 13k and it still pulls like a train.
I just read a post on FB a guy had a M105S with 9000 hrs.
Saxman
L3830 ZD21
Jun 19, 2010
155
Mt. Vernon, IL
2006 L3830HST 650 hrs. Still has the original battery. No repairs needed since new. Only work required was normal maintenance. Love my Kubota
