How do you disassemble this part?
dhmeiser
14
Pipersville
Working on a broken front wheel housing on a BX-1500 and I can not for the life of me determine how to disassemble this. I have taken out the ring clips and all the items I can see. But before I do any more damage by trying to force the two pieces apart with a wedge I had better ask here.
Thanks in advance
Photos are posted below
9,062
In the bottom picture is that the remnants of a circle clip holding the bearing in?
Tooljunkie
May 13, 2014
4,150
34
The last picture, that bearing comes out.
A little persuasion and it should slip out.
Otherwise a slide hammer with a couple hooks to go in the slots and grab backside of bearing.
I think a good slam facedown on a workbench is how i got the last one apart.
Billdog350
Jan 6, 2014
468
East Hampton, CT
There should be a snap ring which holds the bottom pivot assembly into the upper. Some good quality snap ring plyers should pop it off and let you separate that.
