How best to add 3pt hitch
1,004
I would start with a trailer mover frame to get the geometry right. May be able to get one that has some removable receiver so it can fit into that existing hitch area. Then some braces to the top to support it.
Billbo
B2320 HST
Jan 4, 2022
57
South Louisiana
Thanks Russell for your reply. I’m thinking of cutting that ‘Brimley’ type hitch off and welding on a regular 3pt hitch. However, I’m also thinking putting on some dots of receiver hitch to pull with a 3pt hitch
Billbo
B2320 HST
Jan 4, 2022
57
South Louisiana
Also I can buy an inexpensive 3pt hitch off Amazon with receiver already built into it.
Thanks Russell for your reply. I’m thinking of cutting that ‘Brimley’ type hitch off and welding on a regular 3pt hitch. However, I’m also thinking putting on some sort of receiver hitch to pull with a 3pt hitch
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
935
648
PNW-WA
Just a thought. A Belaurus (front) Suitcase Weight Mount looks like it would marry up to that pretty well. That might be something you could track down easily.
Billbo
B2320 HST
Jan 4, 2022
57
South Louisiana
Do you think it would work to just cut off the brimley and weld on a piece of 2” tube steel to work with a 3pt receiver I can buy off Amazon ??
Billbo
B2320 HST
Jan 4, 2022
57
South Louisiana
Thanks but I’m not familiar with a Belarus weight mount??? I’m just wanting to pull this plow thing and use as a rake. Just needing to make or dab a way to use my tractors 3pt hitch. Thinking the tube steel receiver would be easiest
Billbo
B2320 HST
Jan 4, 2022
57
South Louisiana
