Help?
Febrink
Kubota bx2200, bx2660, L6060
Apr 11, 2021
Illinois
I plowed snow most of the day yesterday with my L6060. Drove home and as I approchaed my lane I noticed it was starting to steer like I had a flat. Fifty feet further along it would not turn. I stopped the tractor and got out to look. I noticed I was pouring trans/hydraulic fluid out from the area just behind the front axle. No steering no pedal no loader. I used the truck to pull it off the road. Today I put about seven and half gallons of fluid in it and brought it up to almost full. I started the tractor and still have no hydraulics, pedal, or steering. It was dark by the time I got that far so I shut it down for the night. It is setting half in my lane and half in the neighbors yard. When I started it I did not see fluid leaking. At first thought it was a line at the oil cooler. Now I am concerned the pump is shot also. Any ideas or has anyone seen this before? I did not hit anything and was not working ice just powder snow.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Pump may be ok, you may have just emptied out the system enough that the suction side of the pump won’t draw up the fluid. Cracking a discharge line may burp it. Or it may require removing the inlet line at the pump and dumping fluid into the pump to rewet it and create a vacuum.
There‘s a chance it will prime itself tomorrow when all that aerated fluid has a chance to settle down.
Febrink
Apr 11, 2021
Illinois
Thank you everyone, the line was not loose it was completely off. I put it back on and tightened the clamp back down. Once this was done and started everything worked. There is a whine that I’ve not heard before. I am assuming the air will work itself out or do I need to bleed the systems? Thanks again for the insight!
10,642
No bleeding required.
old and tired
1,919
1,297
Reminder to everyone, check the tightness of the hose clamps to the cooling unit!!!!! Has happened too many times...
