...please. I was using it yesterday and when going to shift the shuttle in to reverse the lever would not move. The linkage is free. I pulled the cotter pin and pulled the shift arm off the lever on the trans case. Today I used a pry bar and was able to move the lever to neutral and then reverse with not too much effort. Tractor backed up no problem. Moving the lever to neutral the tractor had some creep in reverse. Moving it to forward had the same creep backwards. Moving it back to reverse tractor operated normally. How screwed am I? Thank you very much
