I'm new here, having recently acquired an old L2350DT. I was having trouble with starting...starter would click but not crank. I cleaned the grounds and connections with no help, so I bought a new starter, and it temporarily solved the problem. However, after a couple of weeks the problem returned. Most of the time you can get the starter to crank by tapping it with a hammer, however, Saturday it would not crank at all. I noticed that the fusible link was very hot after trying to start, and so I replaced it with a wire jumper. It cranked immediately and much faster, and so I dug a post hole and then shut it down. I tried to restart a few minutes later w/o glowing. I heard a pop and everything went dead...no dash lights, no nothing. Battery voltage is good (12.57 V), and all fuses check out ok.
So I purchased a repair manual with wiring diagram and have begun to check out the circuits. So far I have determined the battery voltage is going everywhere it should, however, the ignition switch does not appear to be doing anything with it. Could I have fried it? What is the fusible link there to protect? The manual does not readily tell me what amps it is rated for? It must have been partially blown and was dropping the voltage to the starter? Obviously, bypassing it was not a good idea. Any help would be appreciated!
