whitetiger
Did the Service Manager, Tech or Salesman ever point out to you that the "New Style Lever" has always been used on Gear transmission tractors and the Cable acuate style has always been and is still used on Hydro tractors??Crank tractor ,let warm up, last place to bushog is where bushog sits outside garage on 3 cinder blocks to keep it off ground,move blocks ,back tractor out of garage,1500 rpm as is close to garage,push in clutch,engage PTO,bushog goes up to speed,cut grass spot , should have used lawnmower. Apparently PTO. Lever on case had only partially engaged gears inside housing,stuck in the middle,when I went to reverse tractor,BANG! PTO lever on case that was stuck disengaged while still turning bushhog shaft,since upper PTO cable end was engaged in slot ,it tried to force the lower lever to reengage the gears ,the difference between PTO / bushog rpm was different than the rpm of the PTO shaft from the engine. I hope this makes sense to others. The torision Spring shown in the pic should be strong enough to keep the PTO disengaged if upper lever is in disengaged slot,my upper lever was still in the engaged slot when this happened,there was enough play to let the lower shaft partially disengage,then try to reengage. If someone as a new style PTO lever please post a picture as I don't know how to do this and only have iPad and not able to do this. Only time this has ever happened to me. Look at WSM and you can see how this could happen. Hope this helps someone else to keep this from happening
