Help or suggestion with possible issues with BX23S
AGrant
Kubota BX23S tractor
Nov 3, 2025
Arizona
I live 300 miles from the closest Kubota shop. Yesterday my Kubota BX23S had issues. Turns on fine, idling is good, when power is engaged and accelerator is pressed to put tractor in motion it shuts off. Turns back on fine. Problem only exists when you try to put tractor in motion. Tractor still moves but can only move very very slow and if you accelerate it shuts off. Any suggestions?
WI_Hedgehog
Apr 24, 2024
878
1,222
Milwaukee, Wisconsin, U.S.A.
Sounds like a bad occupant switch (seat sensor). If you disconnect the plug under the seat and run a jumper wire across the two pins on the side not connected to the seat does it stay running?
AGrant
Nov 3, 2025
Arizona
Haven't tried that, i did lift the seat and noticed two switches and not sure if they both work with the seat
WI_Hedgehog
Apr 24, 2024
878
1,222
There's an operator bypass switch for using the PTO with the driver not in the seat, such as a wood chipper, if I remember correctly it's on the left side and activates when the seat is tilted up. I seem to remember that does not bypass the forward/backward pedal so if the pedal is not in neutral the engine should kill. The other connection should connect to the front right of the seat and that is the operator sense switch (seat switch/deadman switch).
