Help on engine identification.
Grizzdbear67
B7100
Jan 8, 2018
Laverton, VICTORIA, AUSTRALIA
I am an Aussie and I really need some help to identify the model of this 3 cylinder Kubota diesel. Despite a thorough search I cannot find an engine number. There is a partial 7555 on the head cover, but other numbers on the block mean nothing to me.. The motor was originally fitted to a Toro mower but sadly I do not even know the Toro model number. I am hoping that the attached photos might help some-one with more knowledge of Kubota engines than I presently have.
5,691
In your third picture you can see the injector lines coming out of the injection pump. Right where the injection pump bolts to the block there are some numbers in the block. Those numbers are what you are looking for. Probably have to do some cleaning to get a good read. They usually start back by the round valve you can see.
Might use a emery paper then a soap stick to fill the numbers in.
JerryMT
Jun 17, 2017
528
156
The Palouse - North Idaho
All the numbers you've shown are casting numbers. there should be a flat spot on the block above the injector pump that will give the model number and the serial number stamped into the casting.
6,616
Also on the side of the block, Injection pump side, to the rear of the engine will be the engine size cast into the block, It will be a CC #.
FYI: If your asking if this motor will fit in you B7100, sadly probably not, look at the oil filter location.
