Help Needed - Tractor does not move when in gear
armylifer
Mar 26, 2013
2,322
1,079
Thurston County, WA
Today while mowing the lawn the tractor stopped moving, just stopped moving completely. Here are the facts:
1. The treadle moves easily from front to rear. Much easier than in normal operation. When the pedal is pushed for forward movement, it goes all the way to the floor and stays there. The pedal does not return to the neutral position unless I manually push it there. The same exact thing happens when I try to push the pedal to the reverse position.
2. I checked the hydraulic fluid level and it is spot on.
3. The FEL works in all positions. No problem with it at all.
4. The 3PT works properly, no problem at all.
5. The mower goes up and down normally with the 3PT, as it should.
6. The rear PTO turns normally.
7. The mid-PTO turns normally and the mower blades turn with it.
8 The front wheel steering works perfectly.
9. The front and rear wheels rotate normally when in neutral gear.
10. The tractor will not roll when in gear. This is a normal condition and seems to be working correctly.
So, given the above facts, can anyone suggest what may be wrong? To me it seems that a linkage from the treadle to the transmission must have come loose. Can anyone suggest what I should be looking for? Any help is appreciated.
Mak65
L2501 HST
Apr 25, 2019
142
117
TX
I don‘t know the answer but based on description you have listed I’d start by checking the linkages tied to the treadle. Sounds like something isn’t connected anymore. Edritchey provided a WSM. Page 2M-8 may be a good place to start.
11,005
Sounds like you've broken something in the linkage.
11,005
Very common for nut 180 to come off and for the linkage to disconect.
armylifer
Mar 26, 2013
2,322
1,079
Thurston County, WA
armylifer
Mar 26, 2013
2,322
1,079
Thurston County, WA
Thank you NIW! The part that you mentioned is exactly what was wrong. I have noticed that very often your analysis of problems that people post on this site is very astute. I must say thank you for your help. It is appreciated very much. My local Kubota dealer does not have it in stock at the local store but they will have it sent from their other store tomorrow. The cost after tax was $5.49. I have attached a picture of the part that broke in case anyone else is interested.
