Help-Mx5200 first hydraulic fluid change
Brian H
MX5200HST, MTL RK5 Gr, Ford 850, King Kutter brush hog, rototiller, blade, disk.
Feb 8, 2019
44
Waupaca, WI
Did my 400 hr hydraulic change. Manual shows 4 normal plugs to remove. One on each side of rear axle and 2 on belly. However my forward most belly plug wasnt an external hex headed nut like manual shows. Instead it was a allen head plug flush with the belly shown in the picture. So i didnt remove it. I drained exactly 10 gal and replaced exactly 10 gallons. Sight glass shows full. Manual said it shouldve been 11.6 gallons. Did i need to remove that flat plug?
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
581
337
Mandeville Louisiana
If you haven't refilled it yet, I'd suggest removing it per the manual, It's a 10mm allen and you'll need a beaker bar or impact, ensure that the allen wrench is fully inserted. If you've filled it, you probably are OK. You may want to consider breaking it loose and retighten without removing it, that way next time you can easily drain everything. Just my .02
Brian H
Feb 8, 2019
44
Waupaca, WI
Thanks. I did already fill it, so I'll have to pull it next time. That area of the transmission doest sit any lower than the area behind it with the other drain plug so I assumed it would drain. Its just getting 10 gal instead of 11.6 that puzzled me.
lugbolt
ZG127S-54
Oct 15, 2015
5,515
2,227
Mid, South, USA
I never pull the allen head plug it's useless
just pull the other 3
loosen the filter and let as much fluid run out of it as you can, it will almost fill a bucket. Then drain the rest via the 3 plugs listed above. I find that the easiest way. You'll never get all of it out anyway.
