Help! Leaking injector
Codfish
B8200
Jul 10, 2021
26
Hudson NH
I have b8200 we had the heads machined and did the head gasket. The issue is we have the copper washers between the head and ejectors keeps leaking. We have changed the crush washers and the leaks keep coming back. Does anyone have any ideas?
2,994
I'm just a lame brained no nothing regarding your question...but could you put a standard washer in front of the crush washer so it is more forcibly crushed, to seal things better?
Not sure why this should be necessary though...are you tightening the injectors the required amount? Again just questions and no answers....
L35
Jun 13, 2010
520
423
CT
Not much to add but be sure to clean out the bores with a steel wire brush that will get the entire bottom of the bore (square cut) then vac out the bores with a tube connected to your shop vac. Proper torque on the hold down nuts and you should be good to go.
Don’t add additional washers as it will affect the spray pattern of the injector.
Fedup
247
71
Winchester
Injectors should be threaded into the head, right? No hold down bolts. Is it more than one that's leaking? When the head work was done (or at some point in the past maybe) were the seats in the bores dinged up while trying to get one or more of the old washers out? My experience with injector gasket leaks that couldn't be stopped by the usual means ended up being scratched seal surfaces in the head itself. Have you examined closely for that?
Codfish
B8200
Jul 10, 2021
26
Hudson NH
No but I will, thanks
Codfish
B8200
Jul 10, 2021
26
Hudson NH
Thanks, I will look for scratches on the head
Codfish
B8200
Jul 10, 2021
26
Hudson NH
Yes we are
