Help Finding L2600 Seat Mount
TX Ags
L2600
Nov 9, 2018
31
I bought a used L2600 and the seat mount is damaged. Does anyone know where I can find a replacement? Or an aftermarket seat & mount that will fit? I've searched Ebay. Thanks for any help
SidecarFlip
Banned
557
Should be an ISO mount and any seat base and seat should bolt right on. Mounts have been standardized for years now. K&M Seating and Seats Inc., has a ton of seats and bases. In fact I replaced my Grammar base on the smaller M with an air ride base from K&M. Bolted right up and the air compressor is included with the base and built in. All you need is a 12 volt line and you have air ride.
Lycomech96
B2601, loader, backhoe
Nov 12, 2018
49
Williamsport, PA, USA
I just bought a new B2601 and it had a backhoe put on at the dealership. They gave me the non-rotating seat base which I have no use for. Would that do you any good? I'm in PA so shipping would be #$$. The assembly part number is M21700 for my model and several others but I do not see it for yours.
TX Ags
L2600
Nov 9, 2018
31
Heres a picture of the mount. The tracks/suspension parts are worn out. It sloppy and feels like the sear will detach at any time.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Number 010 is Kubota part number: TA040-18430, ASSY ADJUSTER SEAT
TX Ags
L2600
Nov 9, 2018
31
That might work. Would you be willing to let go of the seat mount only? I dont think I need a new seat, just the mount.
Lycomech96
Nov 12, 2018
49
I only have the base. The seat gets removed and remounted on the new swivel base for back hoe ops. Let me get a photo or two tomorrow and measure where the mounting bolts go on the bottom. Mean time look at the parts catalog for the B2601 to see the illustration of the seat base I have. It still has two safety switches mounted on it and springs for the seat itself. And it is unused.
https://www.messicks.com/ku/93386
TX Ags
L2600
Nov 9, 2018
31
I was hoping to revive this thread. I still need help finding a solution for my seat. Basically the seat mounting/suspension portion is toast. I have searched high and low trying to find a replacement or alternative with no luck. I need a new mount/suspension, basically everything below the seat itself has to be replaced. Should I just order new parts from the Kubota dealer? Any help is much appreciated. Thanks!
