Headlights
Randyj
B9200D / BF350 Kubota Loader / L-4530B Kubota Backhoe w - subframe / LP GS1548
Sep 17, 2009
141
Northern Indiana
My B9200 has the small rectangular headlights ( 2" X 4 3/4" ). Neither one works, because the PO screwed-up the bulb sockets.
I'd like to replace them with a more modern light. Has anyone here done this upgrade?
I think that even if I got what I have working, they will not be bright enough.
If I went to a halogen bulb, they'll pull too much on my charging system.
Kinda at a standstill on this.
joekimtkd
B7510DT, 4' Snow blower, 4' Loader, 6' Blade, 6' 3PH Finish mower, 6' box blade,
Aug 16, 2009
204
Durham Ontario Canada
I'm working on my B7510DT's working light right now.
Almost done but as you are worried, I'm worried about power consumption too.
I've bought 2 sets of driving light from Princess Auto. and it has 55 watts of halogen lamp in it. 55 Watts / 12 Volts = 4.58 Amps. for each lamp. but it is really, really bright though.
so if I'm using front lights only it will withdraw 10 Amps at a time.
4.58 Amps x 2 lamps = 9.16 Amps. and for Fuse, 9.16 Amps x 1.6 = 14.7 Amp fuse to use...!
But once Dynamo kicks in to generates power... it would be around 14 Volts.
So it will be around 3.9 Amps each. but I don't have any specs for Dynamo.:(
Well, it might drain the battery time to time but I will use only one set of light at a time. 'cause I have set of Front light, and set of Rear light, interior light too. So, I have to use them with caution...:eek:
As "Ob1" said, should use relay too.:p It will be a lot cheaper to buy lamp kit which comes with everything you need...
Oh, one tip for everyone... I've used trickle charger with timer everyday on my 1992 Grand Marquis for 3 hours per day... and that car is not driven for a few years. and it has the battery that has been changed in 1999 or so.
and it never gave me trouble on battery yet. I could start engine any time I want...;) So, I'm going to do same thing on my Kubota too.
Good luck.
Joe.
