Head gasket shim
11,337
I'm not talking about the head O-ring, I'm talking about the O-ring on the oil pan.
11,337
It’s got high oil pressure it’s getting up to 45 psi would putting copper coat maybe have blocked oil ports
If it's got 45 PSI then what's the issue?
If your getting low warnings you have a bad pressure sending unit, easy and cheap fix.
No copper coat would not plug up the pin pipe.
Are you thinking your not getting any oil to the head?
Have you pulled the valve cover to see if you have oil flow?
codywalters71
Bobcat 763
May 11, 2023
Kilgore tx
I read it’s supposed to have 14 psi
11,337
If it was reading 14psi, you would need to rebuild the entire engine!
43 to 64 is perfect:
15 psi is the low limit at idle
36 low limit at speed.
Like I said before at 45psi your perfect!
