Has anyone actually replaced the HST fan on a BX series tractor?
Robocop5626
BX23 FEL,BH,MMM
Jul 17, 2010
Alabama
If I don't replace the HST fan what happens??
I actually replaced my broken fan. However, I only discovered the broken blades on the fan AFTER experiencing issues with the HST. Even after the new fan, I ended up having the dealer install a new HST to the tune of just over $2,000 a few years ago. It runs like a scalded dog now, but I keep watch over those delicate fan blades. Plus I keep my MMM on as well.
netxtown
68
Blue Ridge, Tx
My fan blades got chewed off several years ago. After I investigated the repair...they are still chewed off and will stay that way. If the tranny overheats and dies - well, it will simply be one more reason to let this thing bury itself in a ditch. Sorry - zero 'pride' left in orange ownership.
wfd2
BX23, RTV900, M8560, and SSV65
Aug 7, 2013
22
Paris, MI
I agree- I just finished putting $2300 into fixing the rear end after a "catastrophic" failure. The dealer said he saw nothing like it with a tractor with just 500 hours on it. Said the transmission looked perfect otherwise (it should have, I maintained it very well). Hell, the original 12v battery outlasted the transmission! Zero help from Kubota stating tractor was too old but the rep said "that's a bummer". I'm looking at LS tractors for my next bigger purchase now.
rnbrn21
BX24
Aug 18, 2015
39
Rochester,NY,USA
I have replaced the fan on my BX24. I broke mine the first time I used the tractor before I started doing research and realized it was a potential problem. As I understand it the BX24 and newer models are actually more difficult to replace the fan than the earlier models. On BX23's and older there is some way to compress the drive shaft and remove the fan without moving the engine. But on BX24's and newer the engine must be moved to get the fan off. You do need to remove the fenders and floor pan to get at the fan, you can't do it from below. The knobs do just pull off but it is not easy. I don't remember exactly how I did it, but I used a board and some leverage to pull it off. It is a big job but I just takes time and is fairly straight forward. The only real problem that I had, was when I was removing the fenders one of the threaded insets of one of the handles stripped out. I had to free it from the bolt and glue it back in. Look at as an opportunity to become very familiar with your tractor. Oh, and don't forget to install one of the aftermarket skid plates available so it won't ever happen again.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
So here's the dumb idea of the century, why hasn't someone with a 3D printer just made a 2 piece replacement fan yet? You could sell those for $50 a shot and get it all day long...
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
While everyone has been on Kubota's case to make a factory skid plate to protect the fan, it's not a secret that it's an issue and the fans don't just chew themselves up.
No tractor out there is without its issues. It's just the way modern tractors are made. You cannot get a compact tractor in this price range that isn't made the same way. Go to any other tractor forum and there will be guys just like you saying exactly the same thing as you are. It has nothing to do with brand loyalty or pride.
Folks buy a brand because it has the right features and price point for them. Part of that consideration is resale vale. That is the only remaining measure of reliability that's left, what's it worth when you go to sell it.
So, I suggest that guys with the problem units, sell them, get your money back out of them and go get something else that meets your features and price point. Just realize, you are rolling the dice again.
If you want bullet proof, buy something pre-1975 that has been treated well, put $4-8,000 into restoring it and use it for another 20 years, but don't expect it to have HST, electronic notifications and all the other modern bells and whistles.
When it comes to tractors, the phrase they don't build them like they used to fits perfectly. I do not expect my L3200 to live 70 years like my D-17 has. If I get 20 out of it, it will be awesome, especially since I paid more for my car than I did for this tractor and cars are only expected to last 10-15 years.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Something is not right with this thread, I am shown as the author of 2 posts early on, but I never made the second comment ???
It's probably a database glitch. The software is actually looking at a large database and if the 'author' field has a numeric error that actually lines up with another author it will happily claim that wrong person as the author. On the plus side, you might be able to edit the comment and say that you didn't say this and for the person that did to let you know so you can credit the real author... :D
Aren't computers fun!? :eek: :rolleyes:
cmatheny1
2017 Kubota BX23S
Aug 29, 2017
I can confirm that Kubota has done nothing to address this issue on the new 2017 BX series tractors either, as I shredded my fan in the 2nd week of operation. Being somewhat mechanically inclined, and knowing this issue as existed for years, I thought for sure that by 2017, Kubota would have addressed this $10 part replacement....right? Nope...alas, these fans are still a) vulnerable to sticks and b) attached with 2 completely hidden bolts that are impossible (literally) to access without tearing half the tractor apart. By half the tractor, I mean the ROPS, seat, battery cover, floor, all knobs (one of which required a torch to yank off), fender and light connectors, as well as the front and rear connectors on the main drive axle (or alternative: remove the hood, unbolt the motor, and slide that assembly forward....but then you need a lift, or strong buddies).
Anyways...I went the a) remove the back of the tractor b) cut a slot in the fan using snips which allows it to slip over the shaft without removing the shaft (this is where I deviated from the service manual) and c) bolt back on using what little play you get at the front of the axle to get a 90 degree universal socket onto the back of the inaccessible bolts and torque them down (a little).
Not cool Kubota, not cool.
jonathan Cornelius
2006 BX-23 TLB
Aug 1, 2018
lillington NC,USA
I have done it without all this disassembly or loosening the engine on my BX-23. It was not as easy as I had hoped but after some looking...it determined that the drive shaft is compressible. This finally gave enough clearance to get the job done from underneath.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
Done mine twice. Posted about it on these forums. Skid plates from Brotek work ok...but with spacers the sides are super exposed.
maclean
BX25D
Jun 25, 2014
242
Lowell, Or
Imho any time you affect the balance of a spinning object you're just asking for trouble. You can put an intact HST fan on a BX in less than 3 hours of work.
6,879
Do y'all think an mmm prevents any stick intrusion on a plain BX 23/26-80?
Seems we've had a couple/few guys had fan damage with the MMM on.... ..Stick got in there just right.
The MMM helps, but isn't bulletproof.
