GST solenoid connector
Mikejones
Kubota L5030 GST
May 11, 2018
Elkmont, AL
I have a 5030GST. Had a stick hit the connector that goes from harness to GST solenoids and break it. Flashing GST on dash and several error codes. Tractor runs good, hydros all work but will not go into any gear. Local dealer in Athens/Decatur AL said all I could do was buy a complete wiring harness at a cost of $1978.00 and change. No wiring diagrams available. Didn't
offer any options and didn't seem to care much one way or the other. Found nothing on internet. Got in touch with Dan Harris at H and R Agripower, Yearwood location, in Fayetteville TN.He went above and beyond and found just what I needed. It's called a repair lead kit and is basically a pigtail with color coded wires that matched the ones coming out of my harness. Spliced them together, waterproofed it as best I could and fired her up. Runs and shifts like new. Cost about $40 and took minutes to fix. Can't believe the difference in dealership response. These guys are great! Their address is 1615 Wilson Parkway, Fayetteville TN - 931 433-3558. Give them a shot if you have this or similar problems unless of course you have an extra $2000 lying around for a new harness and an urge to rewire your entire tractor. Same part TD060-99110 will fit other models too but not sure exactly which ones. Mr. Harris was a life saver for me. Thanks!
whitetiger
Nov 20, 2011
2,983
1,433
Kansas City, KS
TD060-99110 is a standard Kubota part available from any Kubota dealer.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Workshop manual including wiring diagrams here, it may be different being a non USA model, but may be of some assistance in the future. Maybe ask your friendly dealer if they'll give you a copy of their manual if you bring in a USB memory stick?
www.kubota.cz/data/manualy/l-30-wsm-en.pdf
