I want to increase the capacity of my L39, particularly to move the occasional 1 ton plus pallets. I plan to increase the hydraulic cylinder size a bit.
The price I received is a good price. My problem is I do not need 10 sets,
so if anyone is interested, I think this is a great chance to make your machine a real worker. feel free to contact me.
L39 Curl $525/Set of 2. (2-5/8” bore.)
Note:
These would also fit a L45, however the L45 cylinders are already larger than the L39, so the gain on a L45 would be only 3%.
Still a fraction of the cost of a TL1000A Kubota replacement, should a replacement be needed.
L39 Lift $570/Set of 2. (60 mm bore.)
Note: Lift Cylinders are not a direct fit for the L45, as Kubota reversed their orientation on the L45's TL1000A vs. the L39's TL1000.
I had custom cylinders priced at local shops, $1200 & $1,800 respectively, so if I'm in this alone, I will import.
Note:
