The spec sheet on the Kubota web site will list the top speed in each gear or range, at rated RPM. I believe they do it for Ag tires. If you are a wizard at math, you can gauge the different treads by diameter, and different RPM as a ratio. I've never seen a chart. It should be straight forward to make one.
