Ground Speed / MPH
gpreuss
Oct 9, 2011
1,166
Spokane, WA
The spec sheet on the Kubota web site will list the top speed in each gear or range, at rated RPM. I believe they do it for Ag tires. If you are a wizard at math, you can gauge the different treads by diameter, and different RPM as a ratio. I've never seen a chart. It should be straight forward to make one.
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Depends on the model, my M4500 has the ground speed chart decal right on the dash. It's also published in my owners manual.
6,606
Here is one source:
Tractordata.com
They only give you 1st and 8th because the rest are variable ranges.;)
What are you worried about getting a speeding ticket?:D
