*(^!#!*&#))(~*^^^ ground hogs
3,289
Ok one moved into the barn, with in the last 3 days and has ALREADY 3 freekin holes,, 2 of which are under my old tractor letting the tires sink into the ground,, and the 3rd in the goat pen and GKWS how many more... No! Its to close to, to many things and I cant shoot the little *(&^!%#&*%$@! whistle pig,, I know Agway and most likely TS sells smoke bombs, which I have never found to work all that well.
SOOOOOO if, somehow say a gallon of bleach and a gallon of ammonia got spilled down the hole and the holes ahh caved in on them selves sealing them,, would the resulting unpleasant and potentially toxic vapors,, promote the demise of said subterranean dwelling herbivore ??
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
NO DONT DO THAT! Damn man you will kill yourself and everything around you using bleach and ammonia!
E/S
2009 M8540HDC 4x4 w/ Cab
Jan 6, 2010
251
Reno, NV
Just hock a hose to the exhaust of a small engine and stick it in the hole.
E/S
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
27
Ventura Ca
Find someone in your area with a gopher blaster itll work first time I have had the same problem with ground squirrels and it kills them every time .
3,289
Hmmmmm,, ahhhh,, sweetheart I have to run into town, would you mind dumpin this stuff down the hole while Im gone,,,:rolleyes:
Really I think I am going to find some flex conduit and put it over the exasut of my Bout and let it run in to the hole for a while,, and see what happens,, someone on another site said about a gopher blaster,filling the hole with propain and touchin it off, but I figure with all the holes and dirt this guy has moved if I did that I might sink the barn,,lol
3,289
Well its been a couple of days and I couldnt find any flex conduit I did find some hose that fit over the exaust of the BX,,,, filled in the holes I could find, put the hose in the hole filled it in and fired that muther up.. let it run about 1200 rpn for a half an hour pulled out the hose and so far mr woodchuck aint come back,, not as much fun as blowein it up or snipen the bugger but it worked:D
3,289
I am so bloody depressed,,,,, went to the barn only to find A NEW HOLE!!!! same one or new one I dunno?
Don64
BX2360
Jun 10, 2012
30
Cool, CA
My place is overrun with gophers, too...5 acres of gopher holes and mounds. Tried smoke bombs and flooding them out. Been avoiding poisons due to neighborhood pets. Where are all the natural predators!?
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Ah well... most of the fun extermination methods are illegal. Some patience and a .22 rifle are probably the best alternative.
3,289
Ahh not to seem to offensive , but are there any medications we should know about. that you have neglected to consume in the properly prescribed dosage??:confused:
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
No wonder they came back skeets,the fumes from diesel engines don't contain enough carbon monoxide to kill it'll just make em cough:D
you need to hook up to a gas engine.
Dave
3,289
I wonders if them little buggers has a safe room in there>???
tempforce
B2650HSDC
Jun 23, 2012
389
bastrop, tx
if your not going to use a gas engine's exhaust...
set out a pan of anti- freeze for it to drink.. make sure no pets or farm animals drink it...
left over medications....
i had a bottle of predizone left over, sweetened them up with some cornmeal and sugar, then put it out for a treat. got rid all of my extra varmints...
half_full
B2320
May 18, 2012
11
Williamston, MI
I was searching for the root beer carb part of the link below. Very interesting what dry ice can do. Scroll to see the gopher eradication. I have at least one ground hog in my barn now that I just can't seem to get a shot at. I'm thinking of trying the dry ice. CO2 is heavier than air so even if I don't find and cover all exits it should still work???
http://www.dryiceinfo.com/other.htm
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
I have a chipmunk, ground squirrel, too close to my house. Haven't been able to shoot him yet. Finally found where he was going into the ground. Took 16 oz of bleach, poured it into the hole, took a deep breath, turned an 8 oz coke bottle filled with ammonia over and stuffed the neck down into the hole. Immediatly left. No explosion but there was fumes comeing out of the hole. Have not seen the varment since.
