Great Stabilizers
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Mark, I put those new Stabilizer Bars on today and what an improvement. I can't believe the quality and workmanship. They are better manufactured than a lot of implements I have. It made changing implements so simple and quick that now I wish I had got them years ago.
Thanks, Mike
2,221
Thanks, Mike
What chew talking about Willis?????
Where you get em?
OOOOO ...MARKS stabilizers ........My mind was thinking something else!
hodge
Nov 19, 2010
2,861
373
Love, VA
Thank you for your kind words, the business, and being patient!
2,221
Sooo, hoakie,,, when did you start thinking?????
What was the question?????:) no "A" in hokie.......damn, i was thinking for a second.......
back to business as usual;)
OldeEnglish
Jul 13, 2014
768
Western, MA
Definitely worth it! You'll wonder why this isn't stock equipment on all tractors. My b2910 came with them stock and never gave it much thought until I got my b7100 with turn buckles. I was lucky enough to come across Hodge and was extremely pleased with his work.
I need to order a set probably
eddiebob
BX2680, JD 40
Mar 23, 2014
217
Poplarville, Mississippi
Just got home and installed the new set of Mark's stabilizer bars. Took longer to pull the turnbuckles than to install the new bars. Thanks, Mark!
BX23S-1
535
200
No where Special
I was at the local kubota dealer today, i see the B2650 has the slide/pin stabilizers, not turn buckle style. I dont see any reason these couldnt be installed on a BX series tractor.
Grouse Feathers
Feb 16, 2015
1,022
Lovells, Mi
Stabilizers are not the biggest problem with the BX 3 point hitch, at least you can add after market stabilizers. There is nothing you can do about the lack of 3 point position control.
BX23S-1
535
200
No where Special
Just so i`m not confused about position control, you`re talking about the bigger tractors that have the numbered decals on the 3pt control area where you can set it to a specific number to lower the 3pt hitch back to the same location...?
4,145
I don't have a set of Mark's stabilizers, only because I seldom change implements.
I don't think I have ever heard anything but stellar reviews for them.
I f I ever do go that way, I know who I will be contacting.
hodge
Nov 19, 2010
2,861
373
Love, VA
There's at least one issue, the factory telescoping stabilizers for the B2650 don't attach to the lift arm, or at the pivot plates, the same as on the BX- they would have to be adapted. A second possible issue is that they may not be the correct length. There is variation between models, both in how they mount and working length.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
I love mine. With Mark's stabilizers and Pat's quick hitches I can change attachments in a minute and implements in about three.
