What type of grease do most of you use ? I have been using multi purpose black grease. Boy that stuff makes a mess. Oozes out all over. Thinking about switching to a clear high temp , high pressure grease.
Is it clear ? Or black ?I've been buying tubes of grease from Kubota. Good grease and it is high pressure too. Works great! I believe it was $3.50 per tube. Pretty much in line with most of the greases around here.
Thank you for the linkThe black grease is definitely a pain. It gets on things and doesn't want to come off. Hands are especially vulnerable. I only use it on my disc bearing because it is so cheap and the bearings use so much.
Everywhere else, red grease is used. I use TRC 880 but Lucas and several others make good grease. Even the Tractor Supply premium grease is red.
The red seems to come off easier but it is probably just that it can't be seen as well.
If I recall correctly, the Kubota grease is blue. (?) Maybe that is the waterproof grease.
Here is a forum thread that discusses HD grease:
http://www.heavyequipmentforums.com/showthread.php?40083-Best-grease
