Greasing the kubota mx6000
Jms63
Mx6000
Oct 17, 2021
52
17
Alabama
Maybe someone can help me out here, mx6000 front pivot where the front end moves up and down I know the front grease fitting located kindly under the radiator has a relief screws to get grease in but the rear fitting located right behind the pivot point on left side of tractor I can't find one and for the life of me I cannot get grease to go in the grease fitting, I took the fitting off just to see if it was stopped up and it's as open as can be , I can pump grease through it no problem but with it screwed back in I cannot get it to take grease, jacked the front end up where I could hand pivot the axle up and down thinking this might take the pressure off but that didn't work either....any ideas would be appreciated on how to get this fitting to take grease
10,951
The only way your going to know if it's right or not is to drop the front axle, pull off the rear carrier and see if the grease hole in the bushing is aligned with the grease zerk hole.
