Gravity feed fueling question
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
After looking at my container Im having second thoughts about the creation of a high vacuum.
When the lid is on and clamped tight then the unit is tight...maybe too tight.
Here are pictures of what appears to be a vacuum relief valve on the side. Its hard to see from the picture but there is a horizontal split at the tapered end of the valve on the inside view of the container..
So I question my idea because it might start fueling just fine for the first gallon or maybe just half a gallon before a vacuum is created (like finger over the straw method) and then the valve works but maybe not near enough to maintain good flow. I would simply have to try it first. If it fails then I would simply remove the rubber valve and try again. That hole would be covered from foreign materials but just not sealed. It has to have a way to breath anyway.
Also wanted to mention that if you type in "plastic barrel" or "metal barrel" in Craigslist you might be surprised what you find. If this crazy idea works.
3,019
go and get you a tire valve ......less than a buck! drill you a .5 " hole slide it in - remove the stem inside, and keep the cap - bullya !
I use them all the time for my "gas" cans.....
silly government will not allow a vented cap anymore.......necessity is the MOTHER f....of inventions.....:D:):)
Tooljunkie
May 13, 2014
4,150
34
Make a simple bracket, and a chain block or cable hoist. Fill pail, hoist it to proper height. Even a 20 dollar boat winch will do it-they will pull1500 lbs.
a small version of a crane fork. Think thats what they are called. Roofing suppliers use it to deliver shingles up onto a roof.
Use a gravity bowser, will prevent spills.
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Thanks
More great ideas. I need all the help I can get considering I dont know what Im doing :D
Seriously though both great ideas.
Tooljunkie
May 13, 2014
4,150
34
That is a duckbill. Check valve. May limit the fuel flow.also a bulkhead fitting works on a flat surface, like bottom of container. I would experiment with water first. Before buying any expensive stuff.
Mudball
L2501 HST 4WD
Aug 3, 2015
526
25
TN
Thanks Tooljunkie.
Ive actually considered a cheap simply pulley hoist. I just didnt want to go that far with this yet.
If I decide to go this route then it will be possibly a week or two before I can finish and update.
Thanks for the other tips you mentioned as well.
