Grand L60 cab rear work lights?
Technical Ted
L3560/cab LA805 loader LandPride RCF2060 rotary cutter, HLA hyd angle snow blade
Jul 2, 2016
105
Dansville NY
Has anyone installed these? I assume there is a kit, but the price will probably scare me. Anyone hooked up DIY? Any suggestions on what wires to tap into, etc.?
Thanks!
Ted
sheepfarmer
Nov 14, 2014
4,445
663
MidMichigan
Hi Ted, there should be a set of wires with white connectors on them to the right of your seat that are for adding accessories like lights to start with.
There are a couple of sources for ROPS lights besides Kubota, (ebay, amazon, ropslights.com) and lots of guys have added them without getting the Kubota ones, so you'd just have to change the bracket. There also are kits with the wiring done.If you haven't seen Paul Short's (aka Wildfire) video of the lights he added you should view it. Amazing! Someone is sure to post the link or I'll add when I find it. Also search ROPS lights here, many ideas for brackets etc that you could modify for use with your cab. (Cab only has 3 letters so it won't help narrow the search.)
1970cs
1,124
Grand Ledge
The wires are already there by the hazard lamps bracket. The kit L8333 2 rear work light brackets/hardware 2 lamps and switch and directions.
Remove proper plug in headliner and hook the right connector that matches the switch. There are a few of connectors 1 for the obvious, another for rear wiper and the last is the rear defroster.
Pat
