Grand L split to repair?
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,237
Ireland
Yes, I agree, the scratches should not be there, even on a tractor.
Document everything (lots of detailed pictures) and tell them beforehand that you want it back in same condition.
And I understand your frustration with having a major repair on a pretty much new machine. Not sure about the legal situation in your location, but as far as I know in Germany for example you would be entitled to a new tractor or your money back or a repair, at your discretion. You do not have to put up with a major repair on a like new vehicle.
BX23-S,57 A-C D-14,
6,308
re:
When they installed my air seat, they put a dozen or so scratches on the floor board and back window member. Yes trivial on a tractor, but it shows poor work habits on an item the customer has yet taken delivery on. It's all about about the perceived value to the customer.
It's NOT trivial ! Doesn't matter if it's a tractor ! If it was done on your new $60K car, you'd be hopping mad, should be the same for your $60K tractor !!
yeesh, if they can't install a simple seat without damaging stuff, what WILL happen when they tear it apart for the noise problem ???
Agree, take a LOT of before pictures, from all angles. If done properly, no one should be able to tell that they tore it apart and put it back together. Bolts that have chipped paint, should be repainted.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
418
315
NH
If this dealer had such a hard time installing a seat, I would be very concerned about them splitting my tractor. Maybe the person that did the seat only does the easier jobs, although maybe not good at it, and more qualified techs do the real stuff.
I would check with the dealer to see how many splits they have done and who does them. I would then ask to talk to that tech and have them explain the process.
I did that before I had mine done. They had a tractor in the shop that he had split, and he took me out to see it and explained how it was done and also showed me what he was replacing. This tractor had the same oil leak as mine. From the way he explained everything with great detail and had a knowledgeable answer for any of my questions I knew he knew what he was doing.
If you can get the same helpful from your dealership, I would feel comfortable.
Shawn T. W
Dec 9, 2024
813
1,471
SW Missouri Ozarks
Slightly different ... But most pickup trucks these days need the cab to be removed to get to the back of the engine, much faster and easier than pulling the engine ... And I'd think a modern pickup truck would have more details to deal with ...
A couple of years ago I had $6K of hail damage on my pickup truck, they had to remove the head liner, all four doors inner panels, fenders ... All put back together just like new, other than a slight oder of glue for a couple of days ...
I'm not seeing that it would be a difficult or unusual job for a dealership to split a cab tractor today, most medium and bigger tractors all have cabs now.
whitetiger
Nov 20, 2011
3,734
2,151
Kansas City, KS
Why is it unreasonable to expect a loaner? The Op just gave Kubota $50,000+ and in less than 3 weeks it has a serious defect from the factory. Depending on the skill level of their techs, it may take 2-3 weeks to locate the defect, order parts, and repair the tractor.
Hopefully they can actually fix the factory defect PDQ as today is the First day of Spring.
Where does he say he has only had the tractor for 3 weeks?
How do you know it has a serious defect from the factory?
How do you know it will take 2 to 3 weeks to find the concern?
Why would the dealer give a new loaner?
Why would the dealer replace the tractor?
It may have a simple failure that takes a few hours to repair.
This thread has really gotten off into the weeds!!
mikester
M59 TLB
Oct 21, 2017
4,133
2,829
www.divergentstuff.ca
guess all dealers aren't the same.
I have to assume ,you'd happily walk home from dropping off your $60K new pickup at the dealership for a manufacturing defect that'll take 2-3 weeks to fix after they get parts ,and not use their loaner ?
it'll be interesting to see the outcome of this, what was defective and time to repair.
That's old school thinking. Customer service is going the way of the Dodo. Think profit center.
Some dealers will go above and beyond and give you a loaner. More an exception than the rule.
BX23-S,57 A-C D-14,
6,308
He doesn't ,but I assume he'd run his new tractor to see what it can do.FWIW , I clocked 100 hrs in less than 4 weeks.
Only 78hrs and a grinding noise INSIDE the drivetrain.
Most dealers are 1 week turnaround, and busier in Spring, splitting tractor is not a 1 day event.farmers getting priority. Unless the tech KNOWS what it is, not a 'common' problem,will take time to figure out. If it was 'common' , there'd be tech bulletins or memos.
To keep a customer and the 50-60K he just gave them.BTW doesn't have to be new, just a tractor he can use as needed.
That'd be nice but 'grinding noise inside drivetrain doesn't sound 'simple' and if it is inside, tractor needs to be split after the cab is off.
whitetiger
Nov 20, 2011
3,734
2,151
Kansas City, KS
Where do you get the idea there is "a grinding noise INSIDE the drivetrain" ??
What makes you think there are no bulletins or memos about this concern???
Did the OP request a loaner unit and was denied??
A dealer is not going to just replace a customer's tractor; that would have to be done through the manufacturer.
The OP stated he has a tractor with 78 hours that is making a " hydraulic pump (sounds like intermittent cavitation/starvation) ".
Maybe we had better just calm down and see what the concern is diagnosed as before we jump off the cliff.
Tughill Tom
B3200
Dec 23, 2013
1,474
2,157
Turin, NY
Ta Da, finely a voice of reason. Diagnose then repair...... Thanks WT!
aledub
L4060 for now
Mar 9, 2025
25
Ontario Canada
Thanks to all who took the time to share their insight and reason. When I spoke to the dealer he suggested that if it turns out to be something major, a split would be necessary. Nothing has been diagnosed yet and I’m hoping is an easy repair.
At this point I’m going to keep a level head regardless of the outcome and I will update the post when a diagnoses has been made and then what the resolution was.
Fantastic member base here on ott and your help is appreciated.
5,469
Good thinking sir!
I have some prior “automotive dealership” experience, and I can tell you that no one likes dropping off their new car/tractor for repairs. But it happens all the time.
You paid a lot of money I’m sure, and I am not disregarding that.
I have seen people both “blow their stacks” and others that “remain calm but firm".
Usually the “calm but firm” people get better results.
As pointed out earlier, this could be a big “nothing burger” , so theres no sense getting all “wrapped around the axle” for something that might be a 10 minute fix. 🤷‍♂️ ;)
Just my .02
aledub
L4060 for now
Mar 9, 2025
25
Ontario Canada
A 30 post melodrama over what could be nothing??????🤔
Things can get carried away sometimes on forums and passion takes over to be sure. I asked the question in the original post as this is what the service manager and I talked about being a possibility. I wanted to see if anyone that had been through the experience to share their thoughts on that.
It could be a very simple issue. Or it could not. I should know later this week hopefully as to what I'm dealing with.
Like Tractors
Several Kubotas
Jan 1, 2020
99
152
Eastern Iowa
Has anyone had the need to have their L60 split in order to repair a drivetrain issue? Especially a cab tractor? How did the repair go and was the tractor assembled back to original condition? I kind of know the answer I would expect, but I'm hoping to be pleasently surprised.
My 78 hour L4060 is at the dealer for a driveline noise and I'm hoping it's related to the hydraulic pump (sounds like itermittent cavitation/starvation), but knowing my luck it'll have to be split for a more serious issue. In that instance, my ocd will make me trade it in for something else if I have to be honest.
I have a Kubota L6060 from the time it was new I could hear a noise in the cab under certain conditions, it sounded pretty severe. From my experience over the years I was pretty sure it was transmission vibration being transmitted through a cab mount...sure enough the left front cab mount would ground and turn the cab into a giant speaker. Might not hurt to verify that.
Trash Panda
L2501
Feb 18, 2022
284
269
Wyoming
Well OP, if it makes you feel better, they assembled that tractor from a few thousand pieces.
I assure you that it can be done again.
11,757
This comment jumped out at me too! I thought I'd missed the "only 3 weeks old" part but turns out that someone was projecting ... if I'm trying to be nice. 😂
6,759
When I bought my L, I had a pretty long list of deferred maintenance that needed doing. About 10% of the way through that project, just a couple months and under 100 hours, I got a stop use notice due to some potential issue with an under torqued bolt in the HST that could fall out and possibly cause loss of control of the transmission. They initially weren’t sure how many tractors were impacted and the fix, according to my dealer, required splitting the tractor to replace the HST.
There was no timeline on repair and the whole thing was pretty vague at the outset. Of course I wasn’t happy about it, but that kind of thing is a new vehicle problem. And it’s the reason for a warranty. After thinking about it for a bit, I was kind of impressed Kubota was aggressive in addressing a potential issue and was clear it was covered under warranty despite it being a rather pricey fix on a stop use order that originally applied to several thousand tractors across several model lines. Turned out my specific tractor wasn’t impacted so it was down for only a couple weeks and no corrective action was needed.
By contrast, while that was going on, I had a 2006 Nissan Frontier. There were several years around then they had a problem with the automatic transmissions grenading. The transmission cooler was integral with the radiator and there was some internal defect that allowed engine coolant to mix with transmission fluid. That didn’t hurt the engine cooling system but it did toast the transmission, requiring complete replacement, before the operator had any signs something was amiss. Everyone anywhere who knew anything about the issue (except Nissan) knew it was an obvious defect in the radiator/transmission cooler. Thankfully, mine had a 6 speed manual so there wasn’t a transmission cooler.
A class action lawsuit ensued. I got so many notices on that lawsuit my stupid self eventually pulled some skid plates to confirm there were no cooling lines on the manual transmission. I don’t know how it turned out other than Nissan never owned up to it being a defect or covered under warranty and there was some sort of settlement. I got the notice for that too, but paid it little mind as it wasn’t applicable to me.
Point if all that being I wasn’t happy about having problems with a new piece of equipment, but I was happy Kubota stepped up to take care of it rather than deny, delay, defend. And splitting a tractor, cabbed or not, should be routine for a dealership shop. If they can’t do that competently, they shouldn’t be masquerading as a full service shop.
11,757
When they installed my air seat, they put a dozen or so scratches on the floor board and back window member. Yes trivial on a tractor, but it shows poor work habits on an item the customer has yet taken delivery on. It's all about about the percieved value to the customer.
I ordered my MX with the air ride seat but the M6060 that I found on the lot didn't have one. My local dealer happened to have a complete NIB air ride pedestal for the M6060/M7060 tractors and sold it to me at cost since it had been in storage for quite some time.
I've looked through the instructions and it says that the seat needs to be removed via the rear window, the air ride pedestal installed and then the seat is reinstalled through the rear window. This might explain the scratches on the rear glass cross member. When I do the swap this spring I'll be sure to cover as much as i can with heavy welding blankets.
The Kubota grey is easy to fix though using spray paint from Kubota. Been there and done that.
