Look at the glide steer cables and the levers and linkages (each front wheel and then the links on each side of the bottom of the transaxle). All good? Levers and cables not stuck? All free/working? If so, look at the drive shaft. Did it slide off? Seen that before too. If those are ok jack up one front wheel only, or at least block one from turning, then try to turn the other. Does the drive shaft move? If yes, your issue is most likely inside the transmission, though that's not seen by me or my coworkers (yet). If the driveshaft don't turn, you have a front differential issue.
If it's in the transmission, you're gonna have fun.....
