GR2120 front bracket attach
filipows
GR2120
Jan 13, 2025
Eastern Washington
Getting ready for "la Nina"
La Ninia winter is coming. Wanted to get ready. this is the 1st time for me to install one
I am having trouble getting holes aligned for the retainer pin. It almost seem that I need to connect the lift cylinder and go to one end or the other of the travel.
It looks to me like, extended or retracted, it would allow the attach frame to swing enough to slip the pin thru.
Comments?
filipows
GR2120
Jan 13, 2025
Eastern Washington
Problem solved the bolt head in the picture was the problem. The bolt attaches a bracket with sheet-metal shield around the exhaust. There is a hole in the sub frame, zoom you can see it.
Once I removed the bolt the sub frame went right on and pin went right thru. I didn't analyze the geometry. With the bolt head in place it prevented the frame from properly fitting.
