GR2110 transmission steering clutch
Ken T
GR2110
Jun 29, 2026
Lancaster, PA
I am rebuilding the transmission on a GR2110. The levers on both sides where the cables connect and disengage one of the rear wheels when turning the front wheels are not moving more than 1/8”. I pulled the steering clutches out of the transmission on both sides and have found the springs have a lot of force and keep the clutch packs fully engaged. I am unable to compress the steering clutch by hand to release the clutch packs. The only way I can compress the spring is with a vise. It appears the springs have too much tension. Has anyone heard of or experienced this issue?
I have ordered new springs from Kubota, but it is odd that both sides exhibit the same issue.
Thanks!
11,042
Springs don't gain tension with age or use, so your not looking at something right.
Are you winging it or using the WSM for guidance on how to test or disassemble the clutch packs?
