GR 2110 Mower
6,360
Does it crank?
It it just not firing?
Have you removed the fuel line that feeds the injection pump and seen if you get good flow there with the key on (electric fuel pump)
If you don't get good flow have you changed both fuel filters?
The stop solenoid on that model is on top of the water pump housing.
Its a passive solenoid and pulls the linkage to stop not run.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Not a lot to go on. (please use more words)
Are you suspecting the fuel cutoff solenoid or starter solenoid?
Why?
