Good deal or not
Tooljunkie
May 13, 2014
4,150
27
B6100E for 650,havent seen it yet but engine is in pieces. Im guessing it is somewhat destroyed. Engines easy to find or easier to repower?
Any advice is appreciated.
2,191
you could sell parts off and make some money....
here ya "new" engine - shipping might be stiff.
I betcha you get it going!;) - only draw back is it is a 2wd!:)
4,415
Why was the engine dissembled? If you need an engine that little 2 cyl ZL600 might be a tough one to locate.
As 85Hokie mentioned it is two wheel drive. It also has the PTO turning in the anti-clockwise direction, making it's use limited without an $800 reverser if you can find one.
Tooljunkie, You could repower it if need be, but it would be a lot of work.
The final answer would be in how bad you need a project, and is it something you can use when you're done, or what's it value to someone else.
I've talked to a guy who had one that was running fine for sale for $1000.
2,191
4,415
Tooljunkie, my post #3 is all wet! The 6100E is a much more desirable machine then the one I commented about.
I would ask the same questions, though, before I jumped in!
2,191
Odd. That ad claims their D650 engine produces 18 hp @1800 rpm. Somewhat higher than even the D750 engine. Did Kubota make a "high output" version or is this a misprint?
Good question - NIW would know, I just searched for that model engine and it popped up, not sure where their info was obtained.
here are the specs from Kubota - the site is down so I am coping and pasting:
Kubota Tractor Model Kubota Engine Model
B6100 D650
Engine Model: D650 Head Bolt Torque: 32
Tractor Model: B6100 Main Bearing Case Bolt 1 Torque: 18
# of Cylinders: 3 Main Bearing Case Bolt 2 Torque: 26
Displacement (CC): 695 Rod Bolt Torque: 23
Displacement (Cu In): 41.1 Flywheel Bolt Torque: 44
Bore (MM): 64 Rocker Arm Bolt Torque: 15
Bore (In): 2.52 Compression (PSI) Standard: 450
Stroke (MM): 70 Compression Lower Limit: 325
Stroke (In): 2.76
Engine HP (Net): 14
Valve Clearance (Cold): 0.008
Piston Ring End Gap (RV): 0.017
Piston Ring End Gap (AL): 0.035
Main Crank Journal (Front): 1.7297
Main Crank Journal (Center): 1.7297
Main Crank Journal (Rear): 1.7297
Rod Journals (Standard): 1.4553
Crankshaft End Play: 0.012
Front Pulley Nut Torque: 116
Cylinder Liner ID (RV): 2.5199
Cylinder Liner ID (AL): 2.5256
Piston Diameter: 2.516
Dimensions are inches. Torques are foot pounds.
4,415
I just talked to the guy who owns that company. He said he list so much he's not sure, but "It might be a misprint"!
