Glow plugs
Weedman
Kubota zd18 zero turn
Dec 6, 2023
29
L9w1m5
If I remove a glow plug and connect the wire from the ignition directly to it then it should get hot if the wire and ignition are working properly. Correct?
If I create a separate switch should it be with a 30 amp fuse or 10amp fuse?
jaxs
B1750HST
Jun 22, 2023
1,078
814
You might take more time to study up on the subject before trying to redesign it. Otherwise it will cost less to have a pro check it out than putting smoke back.
The only thing that makes sense is poor conection,find it and the problem is solved.
