glow plugs L3450
chris989
L3450
Oct 5, 2016
35
boise
Hello all,
Silly question alert.
Is it possible my glow plugs show light while cranking only? I honestly thought this tractor did not have any. (The yanmar in my boat didn't)
I have never heard a relay, my dash is a mess, only the fuel gauge works.
Anyway, it always starts. Even in winter, single digits, it starts. At 10degrees i have to crank it 10 seconds and it starts. when it is warmer weather it start in only a few revolutions.
Everything else (other than yanmar) had a GP cycle before starting. It is very possible someone has a wire hooked up wrong. A link to a l3450 manual would be greatly appreciated.
Chris
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
Does your ignition switch turn to the left? That’s the way mine is. Turn the key to the left for a few seconds then turn to the right to crank as normal.
chris989
L3450
Oct 5, 2016
35
boise
I've been running this tractor for years and never looked at that switch. Sure enough it has a heat element symbol to the left. Next time i have it in the shop I will make sure i am getting voltage to the plugs..
Do you own a 3450? I have an injector question if I may?
Chris
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
Chris
No sir, I have an L3200. But post your question on the forum. Lots a knowledge around here.
6,607
Chris
What do you want to know?
And yes the glow plugs get power in both the reverse position and while cranking.
Also PMing you a link to download the WSM.
And go to the link below to download the OPS manual.
http://kubotabooks.com/AutoIndex/index.php?dir=Tractor Owners Manuals/&file=L2650-3650 OPS.pdf
