I'm having the same issue, did you ever figure out the problem?My L2800 dies when I move the lever from the neutral position. What gives?
please explain "your problem" ........... dead tractor? if so - what have you checked?Am I missing something? I have read forum after forum in hopes of finding my problem. Now my new problem is that the thread ends before a resolution has been found. It’s like the worst cliffhanger ever. How does the story end? Is it fixed? Did y’all trade it in? Did you shove it in the lAke? Come on throw us a bone here. I need my tractor fixed!
The sad truth is that a few who come for advice, once their problem is solved, move on with their life and do not report back.Am I missing something? I have read forum after forum in hopes of finding my problem. Now my new problem is that the thread ends before a resolution has been found. It’s like the worst cliffhanger ever. How does the story end? Is it fixed? Did y’all trade it in? Did you shove it in the lAke? Come on throw us a bone here. I need my tractor fixed!
L2800 original issue was that it would die about 1 second after shifting from neutral. This eventually corrected itself once the tractor warmed up. That then became a constant problem and I taped the nuetral switch down so that I could get hay out for horses. Now the issue has morphed into the pto clutch lever. As soon as I engage the pto, the tractor dies after about 1 sec. Its frustrating because after speaking with an out of state dealer and then driving an hour to another out of town dealer with switches in hand I have yet to find any answers(the dealers were really a let down) I honestly think I educated them on a few things and electrical gremlins are my worst subject. That’s sad. Sorry for rambling. Skidsteer is broke. Mini x is broke. Side by side is broke and now the tractor. I’m about ready to move into an apartment.please explain "your problem" ........... dead tractor? if so - what have you checked?
I should mention this is a DT model. Regardless of the fact one dealer told me they are all HST. I should also say I’m am new to forums and their protocol or operation. And thank you both for a quick response. Honestly.
On the Canadian Kubota.ca web site I see both DT and HST models.I should mention this is a DT model. Regardless of the fact one dealer told me they are all HST. I should also say I’m am new to forums and their protocol or operation. And thank you both for a quick response. Honestly.
I’ll have to check on reaching the switch while seated. But the switch lever itself is a fixed position. The only adjustment would be achieved by shimming the switch body itself. But mine has shut the engine off once or more when leaning left or right in an effort to see the edge of the bucket.This is a guess... The switch is good but it is not aligned correctly (or out of adjustment). When you are sitting in the seat, can you reach down to manually operate the OPS?
There has been people that had tractors cut off only turning right because they shifted in the seat. If it happens again, I would lean back and put more weight further back in the seat and see if that works.
I wish mine were that simple but what I have come to realize is that my problems are usually unique, one of a kind, never saw that before type of problems. My wife says I’m being negative but I’m just following a pattern. I still think I am being filmed and laughed at during some of this. Gotta be.Now that I remember the time I had a problem, the front of the seat where it tilts up, my pin fell out and one side slide off the bar (shifted the seat). Long shot but it happened to me...
UPDATE....
Upon further research this morning with positive results yet more confusion, the ops check indicated that the seat switch is not operating correctly. With parking brake set, all control levers in the “NEUTRAL” position. Operator on the seat. Started the engine. Engaged the PTO lever and proceeded to stand up, the engine remained running. The only thing I was not sure of was if this is done with the clutch locked in the down position so I tried it both ways with the same results. Now prior to doing this I went on a hunch from old and tired and bent the tab on the bottom of the seat that engages the seat switch downward approximately 11/64”. Am I correct in assuming that my seat switch is bad but by bending the tab I somehow fooled it into thinking it’s not. One other question, where exactly is the OPC switch located? Thank you everyone for your help to this point and for putting up with my rants.
I’m assuming yes it would. But I still have the issue of it not shutting off when I stood up with the PTO engaged. But for now I’m going to bush hog and hope I’m not being set up to hit a yellow jacket nest. That should be good for the cameras. And thank you again for the help.The OPC switch is really the seat switch, the OPC is a cute name, should be called the ASD (a$$ sitting down) switch- if you bent the tab down a bit, that would make the switch work correctly would it not?
