Gear Box for 48" mower deck
mikeb110
L3600, G2160
Oct 6, 2012
Eunice
I have a G2160 with the 48" Grass collector. The discharge is in the back central. The gear start leaking so now I have to change the bearing shaft . I wonder if i can get the gear box complete as one piece or I need to order the different parts . Will have to change the bearing under the deck also as the bearings look bad. If I can get the gear box complete what web site do I go to. Thanks for all help.
Mikeb110
Kytim
Aug 14, 2009
848
15
Western Ky
Hello, Glad your here.
First, I would stop by your local dealer just to get an idea of what its gonna be. You could also look at the Kubota websites illustrated parts guide and check someone like messicks.com. a "NEW" complete gear box i'm afraid would be prohibitively expensive. might could try WKYTP, a kubota tractor salvage yard. Good luck and don't forget to touch back here to let us know whats going on getting this fixed.
quinka
L245DT with FEL and backhoe, B7100HST
May 6, 2011
65
Heflin AL
Is yours a mowing deck or grass collector? If it is mowing deck, I can help you as I take my 48" mower deck completely apart (including gearbog) every year at end of season and go through everything, replace/repack all bearings and replace seals and completely clean deck (easy when it is just sheet metal) then when it is re-assembled, I am ready for the summer mowing (7 acres).
email newdes@gmail.com
