how do you disconnect a gas solenoid from a kubota b7800? the tractor runs fine untill you press the gas and i am trying to find out if it is a fuel delivery problem or an electrical problem and i heard if you disconnect the solenoid then you can run the tractor and if it is a bad safety switch or something you'll know because the tractor will run fine
